450r sat, now won't start
Honda
My older brother bought a 2005 450r (kick start) new in late 2006. He rode it for one year (maybe 5 times) and then it sat. Since he doesn't want it, I want to get it running. It won't start though. It has some type of plastic screw thing on a line (maybe going to carb, not sure) that my wife was turning. Not sure what that did. What should I check/clean to do to get it running? Thanks guys.
thats the idle adjustment, you probally need to put the carb off and take it apart and clean the piss outta it. then i would reassemble put new gas in it and it should fire off. after that change the oil in both sides of the engine and let it rip
Get an owner's and a service manual!!!
What he said, and a valve adjustment. Do not try to start it with the old gas in the tank, you will just make things worse!
This Honda is unique among 4-strokes, because the engine and transmission oils are seperated! Read this: http://www.thumpertalk.com/forum/showthread.php?t=982482
definately take the carb apart and clean it out. its not nearly as bad as it seems. a can of brake cleaner, an air gun, and i bet it'll fire right up.
Just spraying a bunch of cleaner around all over the place won't do it. It is always the idle jet that gets crudded up when stale gas dries up in a carb, so be sure you clean it, or better yet they are cheap so just replace it.
Thanks guys. Trying to get a manual now. Hopefully I can get it running.
^x2!!
which is exactly what i meant when i mentioned an air gun. a can of compressed air will even work. you dont need a manual, its really not that bad. pull the rear fenders, gas tank, and air box. turn the gas off first to the tank and crack the screw loose on the side of the carb to drain the gas inside the bowl (bottom cover). you dont have to take the cables off the carb. pull it out and twist it enough to get to the top and bottom of carb. pull the needle and clean out the passages. pull the bottom cover off and remove the float to get to the jets. remove them and spray them out, spray the passages in the carb. blow it out with air. put it all back together.
just becareful while youre doing it and dont drop anything. lay everything on a rag in order if ya have to. then get used to doing this cause its a very common thing (at least it is for me running around on these dirty coal banks in PA). 2 or 3 times and you'll just complain cause ya have to take so much stuff off to get to the carb lol.
hope this helps.
Cory
If you find that there is a black contaminant in the fuel when you drain the float bowl, it will be time to replace the fuel line also. This 10% ethanol in the fuel eats up non-compatible rubber fairly quick reducing it to a fine black sandy looking crud in the float bowl. Of course this will plug your jets and orifices in a heart beat.
i've also had a bad batch of gas destroy the filter inside my gas tank last year. that same batch destoyed one of my carbs too. it was in my quad for a couple days before all this happened. guessing it was ethanol? ran fine in the orher 2 quads though.... weird.
Thanks a ton guys for the responses. Been so busy with planting and baling hay haven't even had a chance to look at it. Got a manual downloaded and found where it talks about the carb. Would I need to get like a carb rebuild kit?
http://store03.prostores.com/servlet/peakmoto/the-3266/Honda-TRX450R-TRX-dsh-450R-CARB/Detail
http://motors.shop.ebay.com/i.html?_nkw=2005++trx450r+carb+rebuild&_sacat=&_odkw=2005++trx450r+carb&_osacat=0&bkBtn=&_trksid=p4506.m270.l1313
I would remove the carb, open the float bowl, remove the jets, and let the carb and jet soak in one of the gallon cans of carburetor cleaner they sell at the parts stores. After soaking for a day or two, blow it our with compressed air and look through the jets to make sure they are not obstructed. If the float bowl o-ring is still in good shape, I would go ahead and reassemble the carburetor and reinstall it along with a new fuel line. Give it a try then. All you will get in a rebuild kit is a new fuel inlet needle valve, float (maybe) and gaskets/o-rings.
I personally wouldn't try cleaning carb on qaud. If you goin to clean it out u need to COMPLETLY take it apart. Not just jets. You will still have junk in other valves of carb. Take your time and take everything apart so u get it right the first time. I would also reccomend taking pump apart. Metal rod of pump known for rusting (as said above) ethonal eats up/ hold moisture in carb.
Once you clean everything up and make sure of spark don't be afraid of a good pull start if you get tired of kicking...lol
Have fun
Just want to say thanks a ton guys. Finally was able to work on it today. Got what little old gas was left drained and removed the carb. Cleaned it up and put new fuel in it. Fired on the first kick after not running in probably 3 or 4 years.
awesome....glad the first try worked....thats a good feeling
