2005 ktm250sx fork oil meausurements??
these are 48mm forks and yes they are the cartridge type fork or single cylinder. i need to know how much oil to add once i replace the seals???
I know the 2009 KTM 250SX has twin chamber forks and they take approx 360mL in each fork leg for the outter chamber. I put 350mL in mine.
these arent twin chambers. so i figured it will be less considering you only have to add oil on the outside of the cartridge
IMO use oil level rather than volume. Its a while since I done a set of those, but 110mm comes to mind.
