how do you get the cylinder off?!?!
Pull the power valve cover on the right side(rear brake side) and you will find the elusive fourth bolt!
You have a manual, no? You will likely need it for the powervalve.
I am assuming a 98 has a powervalve?
If not, check out an online parts schematic for that engine and will will help you out... some... if you don't have the manual.
And don't forget to disconnect the pv linkage too.
