flywheel puller for xt 350
Hey everyone, just wanting to know if anyone has bought a flywheel puller for a 1990's xt 350 from anywhere and how much it cost them? Is it cheaper to go yamaha dealer and get it pulled for $15 or buy tool? Any help would be appreciated. thanks
it would be better if you buy one then at least you will have it forever
I got one off of ebay. Don't remember the price. There is one on there right now for $32.89 free shipping. I'd say it's worth it.
yea I contacted denniskirk and they gave me a number for one. 27mm x 1.00 LH thread for $18. think i'm gonna got with that.
Don't forget the crankshaft insert: either buy or make one.
what insert exactly are we talking about?
Most magnetos that use this type puller have a male threaded portion on the crankshaft that the puller pushes against. The XT has the same type of magneto, but a female threaded hole for the retaining bolt, vice a retaining nut. If you use the standard flywheel magneto puller there's a really good chance you'll mess up the threads. Yamaha sells this plug affair that goes into the hole and the puller pushes against it. I made my own from a bolt of the correct thread, with the head cut off and a screwdriver slot cut into it so I could install and remove it. Yamaha calls it a "thread protector" and their part number is YM1382. That and the valve shim tool are worth every penny. Making your own shim removal tool is sort of silly when you can buy it for about 8-12 bucks. (PN is YM4106) Other than Motion Pro, I can say from experience that when it comes to special tools, going to the Yamaha shop and getting it from them will be a better idea that most other places. The tools are high quality and last and last. My mag puller is from them, bought it after my previous one died in 1978, still have it, still works great. I have quite a few Yamaha special tools, all are first rate.
Find your free PDF manual here and download: http://www.carlsalter.com/motorcycle-manuals.asp
ok thanks for the heads up, hadn't thought that far into process. Waiting on my puller to arrive next week.
I've tried to get this manual previously but everytime I put in code, it goes to an error screen. Any thoughts?
It did that to me a few times as well, but then it finally worked. But now you have another source.
ok thanks. I already have the service manual guide from awhile back. I thought maybe that the manual on other one was more in depth than the service guide. Thanks anyway.
hey yamaguy55, is the flywheel normaly tight as heck? Does it take some gruntin to get it to break loose?
Yes it does. Remove the bolt, install the crank plug and the puller, with the outer threaded part of the puller threaded in as far as it will go, tighten the puller center bolt until it has quite a load on it, then smack it with a hammer, but not real hard, as it could damage the crankshaft ball bearings. A sharp rap with a 5 pound hammer to the puller center bolt usually pops it off. Don't lose the woodruff key. it has most likely never been off. There's little reason to on ones with a CDI, the old points versions required pulling quite often.
ok thanks for info. I had some problem gettin it off cause the bolt that I cut off was to short for puller to contact so I had to make another rig. But I gotta it off after about 1hr of fooling. Took 10min. to put it all back together. You ever had crank seal leak? That was my problem, i've never had any others do that before.
Yes, sadly, I have had a few crank seals go bad. They were all in two strokes, but it is the same problem and solution. Carefully get the old one out without killing either the crankshaft or the cases, carefully, and lightly polish up both the cases and the crankshaft with some 400 wet or dry paper, and find a deep socket the same OD as the seal, and after greasing the seal lip where it rides on the crank. Give it a few whacks, make sure it is even and square with the cases, and you're done. Don't put anything on the outside of the seal where it fits into the cases. That side is fit dry.
Have fun!
ok thanks for info. I put just a light film of silicone around seal just to help hold it in the case because it seemed like it wasn't a super tight fit like some I've encountered on farm equipment.
Yamabond5 works well for that use. Bond4 is for the cases where they go together. They often don't feel that tight, but I've never had a problem with them falling out.
Edited by Yamaguy55
Hey, thought I was in the clear the other day after running my bike with side cover off. No leaks. Took bike on about a 35mile ride this weekend when it was hot. Than after sitting for 2 hrs, I noticed a small drip. Took cover off and oil trickled out of cover. Doesn't appear to be leaking around or through seal. Any other places that oil might could seep out? Thanks
The only thing I can think of is the screws that hold the two halves of the cases together, I don't think there's anything else in there. Could it be getting in via he harness hole? Not sure if it has a vent.
