jetting help
i have an 01 s model. previous owner did 3x3, jet kit, extended fuel screw. currently it has a 25 pilot jet, 155 main and clip in the middle position on the needle. i have played with the fuel screw a bit and so far have best results with it about 3 turns out. my biggest issue is surging at steady throttle mainly at lower rpms. have very little popping on deceleration. anybody have any suggestions? thanks
vacuum leak?
I too have this same problem
May be wrong but I think the 155 mj is too big for a stock pipe. The 22.5 pj will work better with the extended screw. or stock screw with 25 pj. I have the 25 pilot with extended screw and 3x3 mod and mine is at 2.25 turns for the warmer weather. i live at sea level, very humid and hot. I also am running the 155 but i have a billet tip on the stock pipe which is a bigger outlet but not much difference other than sound. Im on clip three on the blue jd needle.
I have light popping on decel from mid range but from WOT i have no popping. thats why i say the 155 mj may be too big. do a search for " jetting" and "jetting spreadsheet" and look what the others are running.
I think you may need to adjust your needle. or replace it. dependign on what you have.
what needle is it?
i'm not sure what needle is in it as it was there when i bought the bike. i didn't notice any markings on it when i had the carb apart a few weeks back
it directly dictates what jetting you need. any other advice is just guessing till we know.
i may have found the issue. the end of the vacuum plug had broken off. going to take it for a ride in a bit and see if its any better
definitely alot better now. still has a little bit of surge that happens at low rpms at slow speed
