1983 xr200 problems
I have a 1983 xr200, with a bored 250 head. I'm having a problem with the kick start, sometimes when I kick it the lever just seems like it doesn't catch. I'm wandering what it could be. Would it be easier to fix this, or swap the engine out. Thanks, Jordan
Good news, bad news: Honda sells the parts but you will need to split the cases. Make sure the compression release works because it take a lot of the load off the kicker.
The compression release does not work. But when I kick it, it only "catches" probably 3 out of 10 kicks. So I don't think it's the compression release. Would it be worth it to split the case or just look for a new engine
The starter ratchet is a weak point in the 200s and a functioning compression release reduces the load on the starter, prolonging its life. The CR not working can lead to accelerated wear of the starter. If the engine has also had its displacement increased that also puts more load on the starter. A functioning CR also make the engine easier to start. My suggestion is to also fix the CR.
The repair parts are not too expensive but splitting the cases is time consuming and requires a some new gaskets, paying a dealer is prohibitively expensive for a bike as old as yours. Buying a used engine is an option but I have not had good luck buying used engines sight unseen!!:smirk:
does Honda sell the gaskets I need or would I need to somehow make/costomize my own? Does anybody know if a newer 200,230, or 250 motor would fit with some brackets maybe?
Does Honda still sell the parts for the CR? When I had my 81 in to the mechanic for top end rebuild, he removed it and the parts for it are now missing. Possible to rig something up more like the 3 wheelers with a cable on the bars or just a manual switch at the valve cover?
The common failure points on the compression release are the cable and negligent mechanics who remove it.
There are also four bolt on parts; two brackets for each end of the cable along with the activating arms. As far as I know all of these parts are available from Honda and/or eBay. Installing the side cover requires special care to insure the internal lever and cam are aligned properly.
The OEM release is best because it is automatic and only works during the first half of the kicker travel. If the kick was started from the top, by half way down the crank is turning fast enough for an easy start from that point with full compression.
  • Similar Content
    • By Daniel627
      A while back I picked up a '95 XR250R swingarm that I plan on installing on my '90 XR200R in the near future, to save a little weight and have rear disk brakes.
      I missed out on a totally complete rear brake system for $75 a while back which sucks. I look on Ebay every now and then hoping to find a great deal on a complete or near complete setup but no luck lately.
      Is anyone aware if Honda used the same brake system that was used on the '90-'95 XR250R, on any other bikes?
      If so, then I can expand my search. If not, then I'll just keep looking at 250 parts til I find the right setup for the right price.
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
