what's go's wrong with the 09 CRF's?
hey all, i'm looking into buying an 09 CRF450R secondhand, with 15 hours on it, i'm just wondering what problems do the CRF's have as far as reliability go's? i ride alot, both MX and enduro (but mostly enduro) and put around 200 hours a year on my bikes and would like at least a year of not having to open the engine on whatever i get.
i'v heard a few things, like leaking fuel injector's, gearbox troubles, hard starting, flaming out ect, just wondering what issues there are, and what the fixes for these issues are, cheer's.
I've had my 09 for just over a year and had my first part break, the rear rimlock went. Other than that I've changed the oil often and got rid of the stock chain. The starting isn't bad but not as good as my carbed 06. As for flame out, adjust the clutch so the lever has very little play and you shouldn't have a problem. Other than that, no issues for me, although the stock shock is very stiff. People complain of the forks being too soft but its more from the shock being so stiff and feeling unbalanced. It was still miles ahead of my 06 but once I got the shock softened up everything really fell into place for handling.
Why would a FI bike that is perfectly jetted be harder to start than a bike with jets? I always thought that the new FI bikes would be easy to start.
Better watch out by adjusting your clutch to where it almost has no play in it, cuase your going to burn it up for sure riding it like that... :smirk::thumbsup:
efi is ony s good as the map that tells it what to do, im hoping theres an easily accesable map that fixes the problem
Get with Eddie Sisneros here on TT. He's got a MAP that totally fixes what your talking about!!! :smirk::thumbsup:
I've bought my 09 in dec of 08 and just hit 108 hrs & my right side main bearing let go. luckily i caught it early and no further engine damage occured. iI ride strictly mx and have had no other mechanical problems. i absolutly love this bike. if you get that bike you may want to look into getting a rear link really helps balance the suspension & handling. And wow you ride approx 200 hrs a year lucky you!
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
