2008 KX 450 topend rebuild at 350 hours
Bought my bike new in 2008 , have done all the regular maintenance like oil and filter changes every 10 hours , air filter cleaned every ride , shims I checked about every 40 hours .
Inlets started needing shimming regularly from about 300 hrs and i knew i was riding on borrowed time .
Decided to change the inlet valves and at the same time do the piston as the motor had not been opened in 350 hours .
Piston has slight wear on the centre of the skirts , barrel still excellent condition with no ridges or scratches , piston pin had a little wear . All parts still in spec as per manual .
Left inlet valve was very worn , right inlet was better than ive seen on bikes with less hours .
Replaced the inlet valves with OEM valves and replaced piston kit with Wiseco standard compression .
450 was a pleasure to strip as everything is easy to get to , and parts are not small like on the 250's ive worked on .
Wow, that's great that you got that many hrs. I hope I'm as lucky. I am also a nut with the maint. I hope it pays off.
Nice. What type of oil do you use in it? Any thoughts on your bottom end wear? I know your exhaust valves hadn't pulled up, but were the seats pitted and/or bases of the stems coked up?
Was not much carbon around the exhaust valves , lot less than I expected . Could not feel any wear on the conrod .
Using Motul 5100 semi synthetic oil .
I never take the bike near the limiter , most of my riding is done on trails where I use bottom to midrange power .
Good job, I have an inlet valve on my 06 that tightened right up. I shimmed it, but was nervous about it's future. (Was thinking the hard coat was wearing) So I check my valves every ride. But it hasn't budged in nearly 30 hours. But it's hard to shake that voice in the back of your head. We don't want a valve to dance with a piston! heh. I'm currently working on my carburetor with some excellent help from the above poster krannie, and depending on my inlet valve/season. Will do the valves and check the top end this winter!
Thanks Shawn250. You got a good motor under light loads. If the crank is balanced nicely, which perhaps depends on some luck with stock engines, then I guess the loads on the bottom end are less.
My 06 engine feels like it has very little vibration compared to some (or all) other 450Fs I've ridden, and after 295 hrs I assume it means something.
Themitch, once the valves pull up, they are on borrowed time and on the way out. I think you'll find the engine is hard to start before anything worse happens. The EOM Kawi valves and seats are great for strength and wear, but with enough dust and/or hours they'll wear eventually. You get a groove on the seal surface of a worn valve.
You don't need to worry about a valve dancing with the piston just because you need to shim it once or twice. A totally different problem needs to occur for that to happen.
Numroe, I got about 20hours on the bike since I shimmed that intake. Hasn't budged yet. When it does, i'll start to think about new valves
Valves moving on the first initial hours is completely normal,in fact most valves do.With ti valves they might move on the first hours,then keep the tolerance for a long time (100-300) until they start moving.Thats when you need to replace the valves.
Also,it is absolutely necessary to recut the seats with new valves or your throwing away your money.
  • Similar Content
    • By tanner_shany24
      Hey guys, I have a 2012 KX450f and it is giving me major issues. I will give you a run down of the history of it. I bought this bike a few months ago and have only ridden it really once, yes once! When I bought it everything seemed to check out, it ran fine, started fine, sounded fine, so I bought it. Took it out to ride and the first hill I hit it got really hot and overheated like a SOB and spewed coolant everywhere. I thought to my self maybe it was because we were riding trails slow before so maybe when I actually got on it it got too hot. After that though, it began to overheat every 3 minutes no  matter what, I would ride it for 3 minutes, and have to stop to let it cool down because I was scared I was going to melt the top end. Got home and started inspecting, found out that oil and coolant was mixing both where the oil is supposed to be and where the coolant is supposed to be. After some research I found that the 2012 450 had head gasket issues. Assuming that was the issue, I took the head off and got it resurfaced (it was actually decently warped) and put new gaskets in everything top end related. Piston and cylinder looked brand new by the way. So I put it back together, started it up, and it instantly started spewing coolant and oil mixed out of the crank case breather hose. Like literally as soon as i started it and it would make a puddle on the ground in 10-15 seconds. I'm at a loss here, brand new coolant and brand new oil, brand new head gasket and resurfaced head, and it instantly started doing the same thing again? What could it be? Is it worth my time or do I part the bike out? I have put way too much time into this bike to want to tear back into it again unless it is something cheap to fix, if not I am going to post it on craigslist and let someone else deal with it. Overall this whole experience makes me want to go back to a 250T! XD
    • By Sam Mclean
      Hi new to this site.
      Ive just bought a cheap kx450f with what i thought would be a minor issue.
      I was told it was only running with the choke on and i thought easy fix, just a blocked jet. So i pulled it apart as must of the person before me and i find a broken soround thing that the plastic case sits on around the pilot jet. So i appoxy that back on unblock the jets and clean it all out, put it back together and now i try starting it for the first time and see the fuel dripping as it was when i bought it. When i look closer i see it is seeping from what looks like a crack in the float bowl. Ahhh
      So my problem is. Looking for a cheap carby might solve all my problems or just a float bowl at worse case. Now i can find many kx450f being wrecked nearby so im wondering are most 450 carbys the same? Will one of a yz450f work?
      Can someone please help
    • By Sam Mclean
    • By BadcaseofTB
      I missed tracking where this little top hat came out of in my 2011 kx450f. Was thinking clutch or right side engine cover. Any help would be appreciated I can’t seem to find it in the manual.
