Help with Shift Lever
Anybody know the OEM part number? I can't find it in any of the schematics, grrrr.
Every place I've tried to find an aftermarket shift lever hasn't had any in stock :smirk:
Any help would be appreciated :smirk:
Try rockymountainmc.com go to OEM and it will walk you through finding what you need. Great prices and shipping is very fast. Order all my parts from them.
Probably would help if I put what year, 2010.
nov, they didn't have anything for 10's.
motosport its under *pedal - kick starter arm. has the kick starter, rear brake pedal, and shifter.
still not seeing it..... :smirk:
1 PEDAL, CHANGE (COO) 24700-KRN-305
2 ARM ASSY., KICK STARTER (COO) 28300-KRN-305
3 JOINT, KICK ARM 28302-KRN-A40
4 BOLT, KICK JOINT 28306-MEN-670
5 SPRING, KICK STARTER 28333-KK0-000
6 PEDAL, RR. BRAKE (COO) 46510-MEN-305
7 SPRING ASSY., RR. BRAKE RETURN 46511-KZ4-J00
8 SHAFT, BRAKE PIVOT 46513-KRN-730
9 DUST SEAL (17X20X2.5) 46525-KK0-003
10 BOLT, KICK ARM 90103-MEN-A30
11 WASHER (26X10.5) 90512-KRN-730
12 DUST SEAL (15X20X2.5) 91251-444-000
13 PIN, COTTER (2.0X12) 94201-20120
14 PIN D, JOINT 95015-54000
15 BOLT, FLANGE (6X22) 96001-06022-00
16 BALL, STEEL (#8) (1/4)
