It, is, alive!
Well I just fired up my 2006 650L after a new piston & rings and fresh top end.
Started right up and sounds great so far. When I wrapped the top end up I added oil through the valve adjustment plug until it ran out the crankcase level hole. I then put a quart in the frame oil tank. Shortly after start up (15 seconds) I cracked the upper banjo bolt and had lots of oil flow.
I then proceeded to head to my local, desolate turnpike access road and ran it hard through the gears. Right now I have around 12 miles logged. The forged piston make a different sound over the stock slug and its a good sound! Its put away for the night. We shall see if the new Viton valve stem seals do their job on start up tomorrow.
The sound an engine make after being strewn over a large area and put back together is special. I think it wheelies easier or rev's quicker from my crotch dyno. I still have to mount the new tires but its more fun riding!
Oh yea, no oil leaks either (knocking on wood /head). I am an old school Permatex user!
Edited by cal50
Excellent nice to hear..glad to hear you know how to check oil flow to.alot of smokin engines in the last few years due to rebuilds and the person not knowing that it must be done,which always bothers me.....i really feel bad when a guy puts sweat and tears into a rebuild and she seizes up......most engines do not have as much of a prob self priming like these bikes do.......prob because of the dry sump design......
Post pics:bonk: we like pics:lol:
B
I didn't tear the engine down, but I did drain all the oil when I pulled the engine and it was down for 3 weeks. I changed the filter, wiped everything down good, and it wouldn't drip no matter which way you turned it, so I knew it was fairly dry. Before I restarted it, i filled it with two quarts and let it sit overnight, and then spun the motor with the gas off and the plug disconnected several times before I finally started it. I know with cars if one had sat a lot i always liked to spin the oil pump with a drill before firing it up. I have never had a dry sump system before, so I figured this would help and couldn't hurt. Did I really accomplish anything other than making myself think I did?
What piston did you go with?
JE 600R piston for a tad higher than stock compression and less than a full high compression slug.
Hey!
No more smoke on start up. Before it looked like a fighter bomber went down in the garage. I can attest the biggest culprit were the stock valve stem seals. Although they were not visible damaged they were pretty hard. The valve stem was not being sealed. The bike is a 2006 with a little over 10,000 miles.
The amount of crud (oil) burned on the valves and the old piston top was nasty. Its all gone now.
Now to change that whooped rear tire.....
Boy that's prudy......I like them shiny aluminum slugs:thumbsup:
Ok got a question for you, did you notice a power increase with the new shiny parts?
This is from the "crotch dyno" but I really feel it revs faster and wheelies easier now. I am really pleased with the end result. If your going to pull the head off for leaky valve seals its a perfect time to check and clean the head/valve train and remove the piston & jug for inspection.
Now to find some type of rack for it. I have been eying larger tangs also.
  • Similar Content
    • By TheLastByte
      Contemplating picking up a BRP in the near future and looking for some perspective.The current owner claims that the bike has about six hundred hours on it, but there's no way for me to confirm as the odo's not accurate.
      I know brp's have a reputation for running forever on stock top ends, but they must eventually have an expiration date. What should I look for on a high mileage bike like this to make sure I'm not setting myself up for disappointment? Also, What are some non engine/transmission related issues I should look for?
    • By TanSnowman51
      Guys,
      Have been riding my 650L for over a year and a half and have been loving every second! In August I moved back to Reno after finishing up my masters at Arizona State. I have been spending most of my time riding around verdi to stampede and the Dog Valley road area. Always looking for riding buddies.
      Was curious what everyone was doing as far as Daves mods or jet kit for the upper elevations 4,000 to 8,000 feet?
      FMF Q4 exhaust, smog delete done so far!
      Thanks!
    • By Alexandre Askmo
      Hey dear folk!
      I need your help.
      A bit of background info, I’m a complete noob when it comes to holding a wrench and doing anything more than filling up the bike. I have however had an interest for as long as I’ve had a bike to make it mine, and that’s why I’m writing to you now. I just bought a donor bike, a Honda NX650 which a friend of mine is helping me fix up and then modify to my liking (I’m hoping to end up with a gorgeous scrambler in about 9 months).
      We found a hairline scratch in the cylinder and need to bore it. This leads me to my question.
      Should I get a 1st overbore performance piston or keep the compression ratio as is? If so is there anything in particular I will need to modify to tolerate the high compression piston?
      If I do get the performance piston, should I also get a new carburetor, hot cam, and new exhausts? I am planning on new exhausts anyway (2-1 from an XRL) and I’m planning on removing the airbox and getting a K/N pod air filter.
      Again, keep in mind I know nothing, my friend has however fixed up a bunch of XRLs and cars but never really used performance parts. Help me out with the decision please, I would also like to keep the whole build to a reasonable cost (I know this is a very relative number).
      I should also add that I want to keep the DNA of the bike, for example keeping the fuel tank instead of switching to a smaller rounder one as one usually sees in most custom builds. The aim of the whole build is to have an insanely fun bike to ride, both in the city and off-road, as well as giving it a bunch of my personality 😊
      Thanks a lot for any help!
      Best,
      Alex
    • By MrCitizen
      I've been rebuilding/restoring an XR650R for some years now (after toasting the motor in 2013). Sent the motor off to be rebuilt, had a local shop rebuild my forks and shock, and took care of most everything else myself.
      As of a couple months ago I had almost everything assembled and ready to run.
      As a final check before adding fluids to the bike, I decided to stick my boroscope into cylinder and take a look. The results were concerning.
      These boroscope pics looked so gnarly that I pulled the head off the motor to get a more thorough look.
      To say that I'm concerned is an understatement. I have pics of the motor internals pre-rebuild, and can confirm that this is definitely a new piston and replated cylinder. I also have all the old parts from the motor, so it does have a new cam, connecting rod, valves, and basically everything else I expected to have replaced.
      The builder "ran the motor briefly to confirm everything ran alright" and then shipped it back to me. I reached out to him with these pics and he said,
      The piston looks like this because he had it machined from 12:1 to 11:1 compression. The streaks on the cylinder wall are normal for one that isn't broken in yet. Regarding the valve impacts in the piston head: "My concern is that something may have passed through the cylinder. How does it run?" I've never run this motor. I can feel these streaks in the cylinder wall with my fingernail. Did he re-use a piston from some other motor?
      Is this dude jerking my chain or is this motor fine to run?
      He's a fairly well-known builder in the XR community and was recommended to me by guys in the (now-gone) XR650R forum.
    • By Jonas Reppe
      I got my XR600r dirt bike giving me a carb issue that I just can not get worked out. It starts first kick and idles well, throttle cracks off nice and crisp when you whack it, but if you ease into the throttle to just above idle it's a spit and sputter pile of shit! Lol. I can turn the idle speed adjustment up to a fast idle and it starts spitting and studdering just the same. Done a lot of research and it points to the pilot circuit. I put a rebuild kit in it and have taken it apart and cleaned it seriously 12 times now. I'm at the point of looking for a different carb body to try. They're about $100 though. A new keihn carb is $250 on eBay. Any thoughts? That pilot adjust screw doesn't seem to adjust anything until it's fully seated or falling out. It has ran ok in that idle to 1/4 throttle circuit before but it don't now. The last 6 removal/cleanings haven't made any changes, previous ones did improve the throttle snap when you whack it.
      The main needle clip is on the middle groove.
      I checked for air leak with some starting fluid when it was idling and seen no change to the way it ran, indicating no leaks.
      Bike has stock jet sizes, foam filter, stock exhaust. 1,830' elevation here in South Dakota.
      I'm baffled..
