Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
08 450f engine "rattle" just off idle
Hello all.... Just bought a used 08 450f and I've noticed a rattle type sound from the left side while just coming off idle..in pretty much every gear...the bike seems to run fantaastic...tons of power and just had a dealer check over including valve check...just wondering if anyone has any ideas or if its a known issue... Thanks for any and all input..
Assuming correct chain tension, it's common for the condition of the chain and slider to cause a rattle like noise as the chain cracks and sends a backlash load through the transmission when you are at lower revs. I think it's a form of harsh mechanical resonance. I've had it many times over the years. A hooked front sprocket is bad, as is a chain with worn pins or bushes which has too much sideways movement. A new chain and sprockets often fixes it. A badly worn slider can contribute too. When you fit a new slider be sure to put a nice bed of silicone adhesive (clear) between slider and swingarm, as a sound dampener.
If it does it when in neutral then check if the cam chain adjuster is working correctly , if only when riding then more than likely what Numroe said .
Main bearings, main bearings, main bearings. How many hours are on it? You can pull the flywheel or have the dealer do it and look at the cage that holds the balls in place. If it is deformed you found your problem. You or they can do this without any parts, just reuse the metal backed gasket for the ign. cover and lay the bike on it's side as to not loose the oil. Also I replace my cam chain every time I put a piston in it. It's amazing how much noise they make over time that you don't even notice until it's new again.
Like that silicone bead trick numroe,getting ready to put a new slider on will be sure to do this.
Yep good idea, But I cut a piece of rubber gasket material you can get from autozone and add that under a new TM slider. No chain slap noise either. This is after the insulators that come with a TM slider wear out from moisture.
hmm so had the bike out for a few rides this weekend...noise is still there...i think it might be from the chain gaurd...the upper block sorta rattles in the mount..... gonna look for a new chain / sprocket / slider and go from there..almost positive that its not an engine noise...wouldnt worn main bearings rattle even more under load??.. thanks for all the input so far people..
It's just chain slap. Silicone the slider in place till you get the new one.
  • Similar Content
    • By tanner_shany24
      Hey guys, I have a 2012 KX450f and it is giving me major issues. I will give you a run down of the history of it. I bought this bike a few months ago and have only ridden it really once, yes once! When I bought it everything seemed to check out, it ran fine, started fine, sounded fine, so I bought it. Took it out to ride and the first hill I hit it got really hot and overheated like a SOB and spewed coolant everywhere. I thought to my self maybe it was because we were riding trails slow before so maybe when I actually got on it it got too hot. After that though, it began to overheat every 3 minutes no  matter what, I would ride it for 3 minutes, and have to stop to let it cool down because I was scared I was going to melt the top end. Got home and started inspecting, found out that oil and coolant was mixing both where the oil is supposed to be and where the coolant is supposed to be. After some research I found that the 2012 450 had head gasket issues. Assuming that was the issue, I took the head off and got it resurfaced (it was actually decently warped) and put new gaskets in everything top end related. Piston and cylinder looked brand new by the way. So I put it back together, started it up, and it instantly started spewing coolant and oil mixed out of the crank case breather hose. Like literally as soon as i started it and it would make a puddle on the ground in 10-15 seconds. I'm at a loss here, brand new coolant and brand new oil, brand new head gasket and resurfaced head, and it instantly started doing the same thing again? What could it be? Is it worth my time or do I part the bike out? I have put way too much time into this bike to want to tear back into it again unless it is something cheap to fix, if not I am going to post it on craigslist and let someone else deal with it. Overall this whole experience makes me want to go back to a 250T! XD
    • By Sam Mclean
      Hi new to this site.
      Ive just bought a cheap kx450f with what i thought would be a minor issue.
      I was told it was only running with the choke on and i thought easy fix, just a blocked jet. So i pulled it apart as must of the person before me and i find a broken soround thing that the plastic case sits on around the pilot jet. So i appoxy that back on unblock the jets and clean it all out, put it back together and now i try starting it for the first time and see the fuel dripping as it was when i bought it. When i look closer i see it is seeping from what looks like a crack in the float bowl. Ahhh
      So my problem is. Looking for a cheap carby might solve all my problems or just a float bowl at worse case. Now i can find many kx450f being wrecked nearby so im wondering are most 450 carbys the same? Will one of a yz450f work?
      Can someone please help
    • By Sam Mclean
    • By BadcaseofTB
      I missed tracking where this little top hat came out of in my 2011 kx450f. Was thinking clutch or right side engine cover. Any help would be appreciated I can’t seem to find it in the manual.
