Honda CR85 Shockabsorber Setting
Hello everyone..
Does anybody know the maximum compress and rebound setting for 2007 honda cr85 shockabsorber? How many counterclockwise turns does the shock has from full hard position? I've read the owner's manual, but it only tells the factory setting, no information about maximum setting for compress and rebound.
Thanks.
when you turn them gently till they stop, thats the maximum.
Do you mean turn them clockwise or counterclockwise? I'd tried to turn them clockwise and they did stop, but I've never tried to turn them counterclockwise beyond the factory setting because I'm afraid if I turn them more and more the adjuster will pop out or the nitrogen will be discharged.
I have one and it is safe to turn counter and clock wise until it stops!Do it so you can count the clicks and do not force it when it stops!
