Clutch Issue, please help
2007 KTM XCF-W clutch issue.
I mistakenly put Hydraulic Clutch mineral oil instead of DOT 4 break fluid. Rode once with no problems what so ever. Two weeks later I have no clutch control... Opened the oil basket and the rubber gasket was swollen up. Replaced the gasket, drained the oil, and replaced with DOT 4. However, cannot build any pressure so I have no clutch control... :smirk:
Please help. What do I need to do to fix this problem? Thank you.
make sure you properly bleed the line than try pumping it several times, if that doesn't work than you might need a master cylinder rebuild.
I did bleed it properly, but nothing... Master cylinder rebuild sounds expensive...
No, I think it might be $30,its just a little plunger a spring and a cir-clip.
