Headlight how to
I just bought an 05 300 exc with no headlight switch and apparently the previous owner unhooked the wire going into the front bulb, thus no lights, when I plugged the wire in the lights work fine. In an attempt to improve this situation I wired up a simple on/off switch, which works but the smaller of the two bulbs in the headlight shroud remains lit as long as the bike is running.
Is the small headlight bulb supposed to be lit at all times?
I do believe that little lamp is the daytime running lamp. Is it off in the corner of the headlight, if so, that's what it is.
Little Jeff
