Bar Riser Install Q
Two quick questions guys,
What is the torque spec for sm 1 1/8 bar clamps? I am installing the zeta 30mm risers?
Second, Is it ok to retain the ignition setup on the new risers (since you lose a couple threads)?
Thanks
The mounts should be flush up front and then a small gap at the rears correct?
