Clutch cable adjustment on crankcase
I need to adjust my clutch cable at the mechanism on the crankcase.
It looks like I can loosen the bolt and move the small piece to a different position.
When I remove that piece will the adjuster on the crankcase move on it's own because there is pressure on it from the clutch? I don't want to mess anything up because of this.
What is the method to do this without having a problem?
Thanks.
no problems just loosen up and adjust.. it will move around when removing but never caused me a problem
