Should I go down a main jet? 2007 DRZ 400S
Hey Guys thanks for reading. Maybe someone can help me out.
Should I drop a main jet size and go dwn a clip or two? Heres my situation:
Did the 3x3 last year with a dynojet kit(25 pilot 140 main at 800ft above sea level, extended fuel screw) Had a bad bog when I cracked the throttle. I went up and down a pilot jet size to try and fix it but no go, so back to a 25 pilot, which is adjusted within the specs posted on this site. So I went to the third clip on on the needle and things straightened up , untill the bike warms up, then bogs again, BAD.:smirk:
I tested today by blocking the air box 3/4 (pronounced stumble, not any better realy) and then took the air box side cover off(much better! no stumble at all, but no power) I figured I was running rich so I went to the 2nd clip tonight. No more stumble or bog, but doesn't seem to pull like it did before,(After the bog would clear when I cracked the throttle)
Should I drop a main jet size and then try going down a clip or two on the needle jet? would this help fuel delivery and give more power?
Any help would be greatly appreciated. Thanks in advance.
I am having the same issue with my 07 drz400s. I used the JD Jetting followed the instructions for at sea level, cut the 3x3 hole in the air box etc etc... When I cracked the throttle it also bogged down bad. I have my fuel/air screw on my carb all the way to the right and it still will not idle unless i am covering half of the 3x3 hole with my hand. any way to fix this???? Change the jets?? change the needle?? Thanks!
Always jet with your bike at operating temps. Use a clean air filter and fresh gas thru a clean carb.
Cracking the throttle on the stand doesn't mean anything for jetting.
The pilot jet is the only circuit that is in use at idle, so if it won't idle, the FUEL screw needs to come out a turn or two. Turn out to richen, in to lean. Read how to tune a pilot jet and fuel screw.
It sounds like you're both rich on the needle. Raising the clip position leans, lowering richens.
Around 25%-75% throttle, the needle is in play, and when you crack it open, the AP with the leak jet is in use, but chances are, you won't touch that.
just turned the fuel screw out a turn or two the bike idles after a really good warm up. I was cracking the throttle while I was riding in 2nd gear around 33mph the bike would bog down bad and 3rd gear around 44mph the same thing. i will try to raise the clip some time this week. thank you for your help i do appreciate it
  • Similar Content
    • By SNORE125
      Anyone else have 130 main and 38 pilot jets already in the carb I took the wifes ttr 230 carb apart to add the bigger jets and this bike from 05 that I bought new already had them in it? I was reading that they came with a 125 main and a 36 pilot.
    • By Charles Joseph Miron
      Hello all.  Need a helping hand here..
      I bought an older TT225 and am not about to spend almost $600 on a new carburetor for it. So I'm hoping someone can help me out with an idea of what (other than original carburetor) style, type and brand I should go with..  I'm also having a bit of trouble finding info on this bike.  It's a 1986 Yamaha TT225.
      Thank you in advanced
      Charles
    • By Br0ck
      Hey guys, I went on vacation all summer and let my bike sit (2002 CR250). When I got back I ripped it apart and cleaned carburetor and put it back together and it started fine and ran alright, but idled really high. I adjusted the idle screw and realized it was a ridiculous amount of turns out. I can't remember exactly how many but id say 6+ turns out. My killswitch was a POS and didn't work anymore so I replaced it with an oem replacement. My last ride I crashed the bike pretty bad and I was off the bike for 2 weeks. I can't get the bike to start ever since I got installed the new killswitch. I think I wired it right I just replaced one wire at a time and it looked pretty straight forward. I verified it by testing spark while holding it in I was getting no spark but with it in running position it would spark.
      Anyway I am just looking for some base settings for the Mikuni TMX to get my bike running again, my carburetor has a 35 Pilot and 380 Main jet which appear to be stock. I am located in Edmonton, AB, Canada which is about 2500ft and usually ride between 10-25 celcius.
      Thanks for any replies.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
    • By Zach7018
      So Ive decided its time to pull apart my favorite machine and freshen it up, and I'm looking to make some improvements in the process. I already have a 3x3 mod and a JD jet kit done and it seemed to have changed the world. The stock bike just plain sucked and now its a lot better. I never expect 450 race bike power here but I know there is a little more and I'm wondering if the juice is worth the squeeze. I already plan to add a header and exhaust, an FCR39 carb and stage 1 hotcams. After some research it really seems like those places are where the gains actually come from, so would it be worth it to throw a 434 big bore kit at this bike or just stick with what I already mentioned and a new stock bore top end??? Also my rides are often solo and pretty isolated,how much of a reliability headache can I expect with these mods?
