Will a 98 KX125 Header fit a 99 KX125?
Searched but no luck! I have a 1999 KX125, and my header has a huge dent with crack in it. Needs replaced for sure. I found a used one in decent shape but its from a 98 KX125. Has anybody swapped these before to know for sure if it'll work? Any other years that may work? I don't think part #'s are the same but the seller says it'll work. (I'm thinking he just wants it gone) Any Help fellas?
Did a quick search for you and found that a couple of the Kawi parts stores offer a 98 and 99 Header for the KX125 with the same part numbers.
If it's a great deal it should fit.....but a new one (stock) is about 150 bucks.
Make sure it's in great shape, no dents or excessive wear around the sealing ends and you should be fine.
You may also consider upgrading that stock pipe - it's a great upgrade, but you would need to potentialy re-jet. that upgrade alone really wakes these 125's up if you looking for it.
Thx DB rider, I appreciate it! I think I found the same as you, in that the part numbers were the same. However I called a couple local Kawi dealers and they both said no dice on the interchangability. I think I'll chance it it's $60 bucks shipped.. and he may let me return it. I cracked the factory one I had during a harescramble and didn't wanna spend a bunch of money fixing it, due to the fact that I just picked up a 09 kx250f and the 125 is goin up fer sale soon. Thx for the reply!
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
