klx 450r not sellecting gear
I have a klx450r 2008 and today my chain broke and it appers as it hit the gear changer a bit as it left (couple of small chunks), :smirk: once chain was back on the gear changer would not select gear unless i wiggled it either in or out, any advise as to what has happened, would be appreciated.
Edited by senna1983
Sounds like a problem with the internal linkage. Drop your oil and open side cover to investigate a little more. Might just be a simple fix......might not, here's a fiche~
http://www.ronayers.com/Fiche/TypeID/26/Type/Gear_Change_Drum_Shift_Fork(s)_/MakeID/3/Make/Kawasaki/YearID/49/Year/2008/ModelID/7560/Model/KLX450R/GroupID/358489/Group/Gear_Change_Mechanism_
Edited by Rome06379
You bent the outer shift fork, or 'notched' the shift drum. Time to open the cases.
cheers guys realy appreciate the advise will get to work on it. hopefull out ridding again soon.
