Red or blue needle ?
Ok I know the temp and altitude determin your needle as well as humidity levels ... But it is a hard choice if you liv in michigan. Im @ 1000- 800 feet above, and we have a very wide range of temp and humidity durring the riding seasons. Ok mostly high humidity but temp ranges a LOT. From 55- 95 durring the summer times.
So what do you think red or blue.
I say Blue :smirk:
+1 on the blue.
Hard to nail it with such a ride range. If changing during the season is not possible (?) go blue. Better to be rich than lean.
Remember that it's not that big a deal to change the needle... Pick one (Sounds to me like probably the blue), ride it for a bit then check the spark plug/exhaust pipe color.
Blue Needle clip #4...may require clip #3 in hot/humid weather or with stock pipe
I have ridden in the Michigan U.P. when it was 40F to 100F. Blue needle.
Thanks. that is what I did. Just wanted to be sure
