powerbomb header with cv4 hoses
anybody on here running a powerbomb header and cv4 hoses? There is only about 1/4" or so gap between the header and water hose on mine...seems awful close to me..wandering how close is to close
06 crf450
Have you tried putting a little twist, away from the header, before you tighten the clamps?
yep tried that..the gap was a little more before i installed the cv4 hoses i think ...I may try trimming the bottom hose a tad . Its not touching, but closer than i like it
I had the same problemwith this same set up.I trimmed the hose shorter and then wrapped aluminum tape around the hose behind the headpipe no problem so far.
