I have a question for you 41 FCR experts
Hi All. I've got a bit of problem thats puzzling me. The engine is running well but the fuel idle fuel screw wants to be 4 1/2 turns out to idle it's best. Runs and idles OK there but it's too far out. I'm afraid I'm going to lose it. I've went from a 48 to a 50 to a 52 pilot and that doesn't make any difference. Carbs pretty new and I've blown out the passages. Any thoughts will be appreciated.
pilot 52 now
needle EMR 3rd
Main 178
Pilot air jet out
This is not likely related to your issue, but a 178 main jet seems awfully large to be using with the EMR needle.
I'll pull it off and check the slide and make sure everything else looks good. Thanks.
My air box is pretty well opened up, quite a bit more than 3x3. Also running a K&N filter. That's why the 178 main.
Yes..not related to this issue.....The mj is around the average size for a stroker motor...I run a 175mj and EMR needle with open/drilled side cover and K&N in my 485..
