How to Bleed brembo hydraulic clutch
ill be removing my clutch master cylinder from the clutch line have to get the clamps that holds it on the bars welded!! from a crash :smirk: so i was wondering when im re fitting it to the line how to i bleed the system i dont have a pressure bleeder can i do it from hand and tips/steps on doing it appreciated thanks
Use Syringe and a little hose that will fit tight on the bleeder of the slave, (push oil from slave to master) and remove oil to adjust as air and oil is pushed.
^^^^^ +1 That's the only way to bleed a clutch / brake and ensure all the air is removed. :smirk:
everytime i take the syringe off the hose i have to lock of the little nut on the clutch slave cylinder right? so air doesnt get sucked back in
Yes.
I used a large syringe (like for injecting flavor in turkey) and didn't even use one whole thing, so no removing it to refill. Was great! Clutch was acting odd, drained it and filled/bled it in minutes with no fuss.
