Need a new throttle
My throttle is sticking. The cable is entering the housing because it's missing some parts including the cover. It's lost so I need a new one. This would be for a smaller bike, an LEM. Will any throttle fit it?
http://www.partsforscooters.com/Dirt-Bike-Pit-Bike-Throttle-housing-173-5#
http://compare.ebay.com/like/160450432304?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y
Need a cheaper one. Not my main bike. It's hard to find LEM parts for older 90's bikes.
If it has a standard size handlebar, you should be able to use just about any throttle. Try a salvage yard. Bring your cable and what's left of the throttle. You might find a close match.
The throttle cable end is the big question. I don't know if the distance from the end of the cable sheath to the end of the steel cable is standard among makes/models. I would measure it as installed on the bike (length with throttle closed, and length at wide open), then try to match that up with various junk yard pieces.
