03 yz40f running lean?
My new to me bike is running poorly. Wont kickstart(have to jump it), has a huge hesitation, and pops off throttle. All leading me to believe it is running lean. Now how can I fix this? I tried the adjustment screw on the bottom of the carb, and whether in or out and everything in between it still ran horrible.
Mods:
Full DR. D exhaust
Swiss cheesed airbox
Boyesen acc. pump bowl
I cleaned the carb, reset timing, checked valves, and did an oil change/spark plug swap and it got me nowhere.
Sure the valve clearences are good?
Fuel is fresh?
What happened, no matter how insignificant, sionce it ran properly?
Valves seemed ok, a little tight on the intake side. If that is a possible culprit I drop the bike off at a shop to have them do it as I tried to figure it out and had a bit of a tough time when thumbing through the manual
