Hanging Rock 200, DRZ finishes,
:smirk: I just unloaded my DRZ from the trailer. It is covered with a thick coating of southern Ohio mud. My body is sore and a bit bruised up. The bike ran well despite multipule spills in the goo. Most guys riding the event had fake dualsports and by this i mean bikes like Honda CRF 450s which in no way could be considered real dualsports. IE no horn, no turn signals, no hi.low beam, etc. The mud was nasty. I fell three times trying to negociate a very steep off camber left hander. Damm im not in as good of shape as i once was. I held the DRZ flag high, despite the army of those orange bikes. Your DRZ Bro, Mitch. :smirk:
I loved riding my kx250 with 4x4 quad riders in the deep deep mud of the michigan swamps . they were always suprized with how well that thing could plow throught it. man I miss my 2stroke. sorry all you 4strokers ( me to now) but they are just way more fun.
+1 well done to finish. I remember when i finished my first hare and hounds on the drz i was beaten but pleased to have used something a little different in a field of ktm's, wr's etc.:smirk:
Yea, i know what your takin about. The 2 strokers seem to negociate the nasty mud just a bit better. I swear my DRZ weighed 20 pounds more with all that mud clinging to it. Happy i finished the event in one piece. I will try to be a little prepared for my next event. IE, a roll chart and get my front suspention a bit more dialed in. I weigh 210 with my riding gear. I set the rear end sag, but the front end seemed a bit stiff. It deflected in the ruts quite a bit. My gut feeling is to soften the compression dampining a bit. Anybody out there in the Thumper Talk Nation have any stock suspension adjustments for a east coast type of trails for a guy of my weight and ability? I used to be ranked as a B class rider. Bike is a 01 e model with fresh 7.5 weight fork oil installed. Thanks Mitch :smirk:
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
