KDX 200 rear wheel bearing
I need to change the rear wheel bearings on my 1998 KDX200. I am no mechanic but have done wheel bearings on other dirt bikes. I have never used bearing pullers. I have always managed to knock the bearing out from the other side. Is this possible with the KDX? I took the wheel off and it seems like the spacer is tight and wont move to the side enough to give room to get a good contact on the bearing.
It is tricky but possible. I did the rear wheel bearings on my '03 last year. Takes some patience since you can't get a good hit until you get the bearing moving a little.
the spacer is just tight, it should move, just keep trying. you have stock wheels im assuming.
My spacer REALLY tight. Once I got the bearing to move maybe 1/16" I was able to slide the spacer over and get a good bite on the bearing to drive it out.
I had that problem with the KX wheel I got in the package deal of fork swap parts. Everything was amazingly rusted up, and I hammered for half an hour with no results. Finally took it up to the shop and had the guy pull 'em with his slide hammer puller. Was worth $10 to just get them out and move along.
Thanks for the replies on this. I took the circlip out and found the inner spacer would move quite a bit on the opposite side with a bit of force.
I was able to knock the bearing out reasonably easily in the end.
Just waiting for the new ones to arrive now.
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
