2006 trx450r engine swaps
Honda
I'm looking at buying a 2006 Honda trx450r electric start with a basket case engine. I can get it pretty cheap. Can anyone direct me to a post of any other engines that will bolt in? If I'm looking for a used engine: a kick or electric start TRX450 engine would be ideal, but I would consider something with less power (like a trx400x engine) if it would bolt in without much fabrication.
The 2006 had an hour meter installed when new and only had 75 hours of run time on it. It is a friend of mine and I know the hours are accurate. The piston failed and ruined the cylinder, head, and looks like it ruined the case too. A rebuild of the existing engine would be more than I would want to take on as a project.
Thanks:ride:
