1997 CR125 Cluth
Hello everybody i have a 1997 CR125 that i purchased it is perfect except the cluth is very stiff and hard to pull in compared to the newer bikes. Is this normal?
Nope. It might be a good idea to inspect the clutch cable and also to inspect the clutch and basket as well.
Thanks
The clutch pull on my 97 was the same way when I acquired it. I bought a new cable and a new lever assembly with bearings. I cleaned and lubed the cable bracket behind the side cover as well. The clutch pull is nice and easy now. I think a lever with bearings is a must for easy operation.
