TPS Diagnostics
This question pertains to a 250X so pardon me if the specs are different, but I've seen threads in this forum that makes me think things are similar, if not the same.
My manual gives me a a standard of 4 - 6 kohm and a formula to check TPS at idle. Is 4 -6 kohm = 4000 - 6000? And what is supposed to be 4000-6000? Is A in the formula supposed to be 4000-6000?
The formula:
A (resistance between blue and black terminals (the outer ones on the plug). I get about 3000.
B = TPS resistance at idle = A X (.13 - .15). So...if A is 3000, the range is 390 - 450.
My manual says to adjust the resistance between the yellow and black (middle and black) to the calculated resistance. So adjust to what??? 390-450?
I'm no electrician and the manual wasn't written for someone like me.
I posted here because more action in this forum than 250 and trying to get bike right before Memorial Day weekend.
Thanks for any help.
Dave
The manual is telling you to check the overall resistance of the TPS resistor between the blue and the black. Should the measurement be in spec (4-6K resistance 5k ideally being what they're looking for) you want 650-750 ohms at idle.
If you find the over all between blue and black to be different but still in spec they give you a formula to correct the adjustment so you can get the TPS set properly to the spec the ignition is looking for at idle.
So, your assumption is correct. BUT>>>>
The issue is this; The 3k your measuring isn't high enough. Your TPS is dirty or something because your not getting enough resistance across the blue and black.
That is going to end up causing an idle lead timing issue. In other words, the lead time for the ignition will be incorrect because the TPS will be sending the wrong info to the ECU.
Thank you! I've loosened the screw and slid the sensor from one end to the other and that has no effect on the 3k. I guess maybe that not going to surprise you because it sounds like the adjusting part is for yellow - black resistance at idle (i.e. throttle closed).
I also removed the TPS from the carb and looked at it and don't know how to clean it or anything. It seemed clean inside the o-ring but I didn't move it far from the carb so I could make sure and put it back on exactly as it came off.
Should I try to fix it somehow or get a new one?
Thanks again!
Dave
If you can get the sensor apart and clean it maybe you can save it. The thing about it is this. Its a sweeping variable resistor. There is a piece of resistor wire thats is wrapped around a core that is then swept by a conductor that is attached to the yellow wire. If the contactor that sweeps the wire has rubbed off and is shorting the wires the overall resistance will fall.
If you can clean the swept area of the resistor you may be able to save it, but its probably not worth saving.
Now setting that stupid thing Ive got some experience in too. When I set the one on my 426 (it did the exact same thing on the Yamaha) I got the idle perfect before plugging it in. Then I set the TPS to where I had zero bog when I wacked the the throttle open but the engine still returned to the same idle.
The ECU only has so much timing built into it. Where you start that timing is pretty key to preventing engine laziness and detonation. You want as much timing as you can get without it pinging or detonating. If you do this by ear, you'll probably be perfect. Then check it with the meter just for shits and giggles...
Cool! Thanks for the help! Good gas for you if I can.
Another question...with the TPS unplugged, how did your bike run @ idle...accelerating....and if you turned off the gas did she decelerate promptly?
Dave
Update -
Turns out my volt/ohm meter that I've had for like 35 years has gone south. Checked my son's bike and his too had an out of spec reading for A. I was like...hmm... So...went and got a new digital multimeter and rechecked. My TPS is in spec for A but was out of spec for B. Adjusted to be in the middle of the range for B. All is well. :smirk:
Thanks.
Dave
Dave
ya, once I got the TPS set properly it'd return to idle correctly.
One of the hanging idle issues is the idle speed and fuel screw settings. If you don't have the fuel screw set right and end up with the carb slide higher than it should be, you end up telling the TPS to start to advance the timing before you should really. Thats why its fairly important to get the fuel screw and the idle speed correctlt so the TPS can accurately tell the ECU/CDI whats really going on.
3D ignition maps are bitchen...when in focus. :smirk:
One way of setting the TPS is this (Its not described anywhere..but I did it by thinking about it a bit)
I set the idle speed and fuel screw to perfect. (burned the shit out of myself more than once)
Then I plugged the TPS back in.
Idle speed went up...
I backed the TPS off until the idle speed went back to normal. I advanced it till it sped up again...then backed it off just to where the idle would be normal and tightened it up.
Basically, I set the TPS to advance the timing with the smallest amount of throttle input I could adjust into it.
Good tips Shawn! I'm getting an understanding of how it works. Thanks!
On my 250, the TPS is totally behind my frame so I can't access it to adjust it while the bike is running. I can barely see it...let alone get a tool on it to loosen it.
Dave
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
