Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
Overheating problem again. Please help..
I was riding my 03 crf450r through the woods and i never get out of first gear, im on the clutch alot. My bike overheated 3 times in one day. I have to keep refilling the coolant every time i wanna ride. Its really gettin on my nerves too. I was riding behind a kid on a crf80 and he was takin his time up a hill so i stopped at the bottom of the hill and waited. I was lettin the bike idle for maybe 1-2 minutes and i looked down and steam was blowin everywhere. A few drips of coolant came of with it. I just shut the bike off and pushed it home. (because i wrecked it like 10 minutes ago and my brake pedal poked another hole through the jbweld on my clutch cover but anyway) i looked down and i was leaking tranny oil everywhere too so i just pushed her home. Any suggestions for why she overheats so much?? Im thinkin about tradin for a 250f :smirk: because the 450 is too much for the woods. Any advice would be appreciated. Thanks a billion.
Faxon
overheats alot cause you.. "never get out of first gear, im on the clutch alot" AND .. (your stopping) "lettin the biek idle for maybe 1-2 MINUTES". :smirk: It no likey that. it's a race bike, with a pretty big motor that needs to be going about 5-7mph to have much cooling effect. That said, you could try some oversized rads, the china ones, $150 maybe? Will solve some of your issues, but that just isn't what that bike is designed to be doing.
If you can`t get out of first , you need a smaller bike! The crf is a nice bike but , if your riding woods and can`t hit sec. gear , its diff. to much bike for you. You would have more fun on a 125 , or a 200 ktm.
If youre slipping the clutch in first youre not moving fast enough to push enough air through the rads and it WILL over heat. Sitting for a minute or two doesnt seem like that big of a deal but the engine was already hot from plodding along at 2 mph. Then you stop and the super heated coolant pushes past the cap and youre done.
Short of a different cam, lower compression piston and a bigger radiators you really dont have a decent fix.
What you need is a 250X, not a 450F for that type of riding. The perfect bike is really an air cooled XR.
I woods ride my 08 450 and with regular coolant I overheat, especially in the tight technical stuff, any way I have completely flushed that green stuff out and filled with engine ice works great. Also bolt in a fly wheel weight, takes out the crack on a 450, it will make you feel comfortable and therefore faster just my two cents worth
Thanks guys, I appreciate those replys. Maybe I will look into getting a smaller bike. I just LOVE the snap, power and speed of the 450r. Im going to switchback raceway this saturday to ride the race track and maybe give racing a shot. If I like it and arent to bad, I'll keep the 450 for race and maybe buy a 250f or 125 2smoke for woods. If not then Ill trade for a smaller bike. Thanks a billion
Faxon
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
