Takegawa 146 +R Kit
Takegawa continues to push the envelope in XR100 engine development- and introduces their stroker crank the to SCUT +R 62mm (136cc) kit. :smirk:
Takegawa Bore kit 146cc, (bore 62mm x stroke 48.5mm). Complete bore with the new Takegawa +R Super Head design with the S-Cut piston kit. This kit incorporates aluminum roller rocker arms, hollow cam shaft with oil jets incorporated into the lobe design as well as the unique S-CUT piston design with Takegawa's patented oil jetting cylinder to provide extra lubrication and cooling.
Head criteria:
Large port intake, 29mm "D" shaped
Valve diameter, Intake 28.5mm, Exhaust 23.5mm
Valve stem diameter, 4.5mm
Valve spring, Double spring progressive design.
Rocker arm, Aluminum with roller bearing tip
Camshaft holder, NEW DESIGN with oil jetting to lubricate the top end
Cylinder criteria
Nicasil Aluminum coated cylinder
Patented Oil jet sprayer to cool and lubricate piston
S-CUT design, no case mods needed
Crankshaft criteria:
Weight reduced counter weights
Surface treated flywheel surface.
Only $1,899.99
I need to start saving up my allowance.
Wow!!! Little over 22HP!! Are you kidding me?? Just when I thought my Stage 3 motor with 18/19HP was crazy, that's just nuts!!
I wonder how long the tranny will hold up with power like this? I'm worried about mine, but it seems like it's doing fine so far!
Wow that is impressive. Someone loan me $2k and I'll be the first one to try it :smirk:
:smirk: Or . . . . you can get a complete Crf150rb. :prof::smirk::smirk:
Yep already got that one covered
Still working on getting it prepped for the track :lol: That doesn't mean I don't want to make my 100 more competitive :lol:
Thats the big question fo sure! I feel that RR is harder on the trans than MX...
Its possible to get into the 155-160cc range being a little creative.. and throw the +R head on top- O' MY!
Sounds like Dr. Jekyll and Mr. Hide aka Stormnnorman and Firepower354 might have a one off cocktail mixing up for +160ish cc INSANE
Still working on getting it prepped for the track :smirk: That doesn't mean I don't want to make my 100 more competitive :smirk:
HEY- I got one like that- its missing a few parts key parts tho- like the motor lol
Mine has the motor but is disassembled awaiting a new spring for the recently re-valved shock and springs for the forks, not to mention the $$$$ to get my wheel set ordered.
