11 no spark
After only 2 race weekends we have an 11 with no spark
I'm lucky to have a 10 CRF250R and 09 CRF450R to swap parts from
Still no luck though. Between both bikes a lot of parts have common part numbers but some are different too
so far I've swapped
Kill switch from a 2010 250
stator from a 2010 250
condenser from a 2010 250
coil from a 09 450
ECU with a unit from a 2010 450
the condenser and ECU have different part numbers.
and I haven't had time to swap the rectifier yet.
I'm not holding out hope that the rectifier will solve the problem, so I'm looking for other suggestions
thanks
Well not sure if you've tried this, but my friend 09 450 did the same thing, and when we disconnected the plug that goes to the fuel pump and kicked it over it got spark again because I guess his fuel pump was putting out to much resistance since the motor was locked up in the pump. Well anyhow it's worth a try...:smirk::thumbsup:
Identified the problem to be the wire harness. I don't know if its an open or a short since I don't have a wire diagram.
I'll a little pissed.
Well of course it's the wireing harness if your not getting spark. But what part of it is the question?
Of Course???
I've never seen an oem wire harness go bad until now. I've been into motorcycles for over 45 years.
Do you know how many spark reliant electrical components there are on a fuel injected 2011? outside the obvious, even the injector assembly has to be working to have spark
Of Course???
Yes of course it's in the wiring harness if your not getting spark, being that's where the current has to go through to make it have spark... THis we know. You obvioulsy have a bad connection going on somewhere or it's the more obvious places , like your stator or coil. Just got keep checking and rechecking everything to do with your harness... :smirk::thumbsup:
Of Course???
+1
Good luck to you, sucks you have to even deal with this at all
Actually after toning out the wire harness last night it turns out that my wire harness seem to work as long as the TPS is not plugged in. When I connect the TPS I loose spark.
The TPS is indirectly connected to the kill switch, but I know its not the kill switch since I have it disconnected.
Have you tried starting the bike without the TPS plugged in? Or better yet, have you checked the resistance on the TPS? Is it open? Is it shorted dead across?
Thanks for your response:
I haven't tried running the bike without the TPS. connected. And I really don't know how to check the resistance.
One thing I do know, since I have the luxury of having an 09 in the garage. I took the whole throttle body from that bike an plugged in all the connectors (map, injector, and tps) to the wire harness of the 11 and have spark. So it appears to be the TPS for sure. Unfortunately it can not be bought from honda without buying the whole throttle body.
