Problem with neutral
Never had this problem before on this bike.
I can not switch to neutral while bike is not running (engine stopped). The 1st or 2nd, nothing in between.
If you hold the lever with a hand it stays neutral. Just let the bike roll a little and it "falls" in gear. :smirk:
While the engine is running, it's quite easy to switch to neutral. Bike runs normal through the gears...
Any suggestions?
Most people have problems trying to shift it in neutral when it's running. I would say to try rocking your bike a little back and forth (while in first gear and clutch not pulled in). That will move the gears a tiny bit and should make it easier to shift into neutral. When your motor is running, it is moving the gears for you.
What are you using for transmission oil?
I use 10w-40 motorcycle engine oil as manual says.
I'm not a first-timer and I know how to get neutral on any bike.
I'm talking of weird situation I faced with last night. I rode bike well 2 month before it and never had problem with neutral.
