Strange shock piston RM80
Here's the pic of the piston with it's broken o-ring which was around the psiton as a piston band.
It's out of a RM80 99-00 (imho96-01 should be the same though)
anybody has an idea what piston this is? imho it's not the standard one.
Now i'm looking for either the correct piston band or a new/used piston.
OD is 32mm, ID is 10mm, rod OD is 12.5mm
Any ideas, gentlemen?
whats the OD of the piston groove (ID piston band)?
Is it Showa or KYB? I have seen that kind of piston in -81 125 RM shock (KYB).
the inner dia is 28mm, the second 'ring' is 31mm and od is 32mm
@Jusa it's a Showa
so a piston band used in the inner groove has to be 2mm thick.
if you are interested in an open piston band (not a ring), I have one, 10mm width.
just let me know...
