Transmission ratios
Anyone out there know the transmission ratios for a 97 YZ250?
Thanks
Anyone Know?
Here's my '98 YZ250's, they should be the same
Primary 21/63 (3.00) (crank to clutch basket)
1st- 14/27 (1.93)
2nd- 16/25 (1.56)
3rd- 18/23 (1.28)
4th- 22/24 (1.09)
5th- 21/20 (0.95)
Then your sprocket gearing on top of that
Thankyou for the reply. Unfortunately the 97 is different. At lease I think it is ,because of the final drive difference. 97 is 13/49 and 98 is 14/50.
Again thankyou. Does any one else maybe know ?
part numbers are identical >
97 >
4MX-17151-00-00 GEAR,5TH PINION
4XL-17131-00-00 GEAR,3RD PINION
4XL-17141-00-00 GEAR,4TH PINION
4JX-17121-00-00 GEAR,2ND PINION
4MX-17211-00-00 GEAR,1ST WHEEL
4XL-17251-00-00 GEAR,5TH WHEEL
4XL-17231-00-00 GEAR,3RD WHEEL
4XL-17241-00-00 GEAR,4TH WHEEL
93834-13207-00 SPROCKET,DRIVE 13T
93834-14049-00 SPROCKET, DRIVE
93834-15076-00 SPROCKET, DRIVE
98>
4XL-17251-01-00 GEAR,5TH WHEEL
4XL-17221-00-00 GEAR,2ND WHEEL
93834-15075-00 SPROCKET, DRIVE
Thank you . I guess my final drive info. on the 98 was wrong.The trans must be the same from 96 to 98.
Yes, only the final drive (sprockets) changed from '97 to '98.
