Hour meter wire
I had a friend give me an hour meter, but the wire is missing. Can I just use a normal copper wire? Is it one strand or two? any particular gauge? how long? Does the wire need to have a certain number of wraps on the spark plug wire?
Thanks
John
Unshielded vinyl/rubber jacketed copper stranded wire small enough gauge to fit into the meter. (has outer jacket, but no shielding drain wire), long enough to reach the spark plus w/ 4-5-6 wraps.
Thanks
John
probably use stranded, then wrap it around 4 times and zip tie it.
Great, thank you
John
