1985 cr 250 rads
Anyone know which newer cr 250 radiators would work on a 1985? (some modification is ok). Looks like 86-89 would, any newer ones?
When I bought my 1988 CR250 (the ROACH bike) it had a 1985/86 radiator on it.
The mounts are the same but the thickness of the radiator is thicker and shorter on the 1985/86 radiators as compared to the 1988/89 radiators. I also believe that the part numbers for the 1985/86 radiators are the same. Not sure about the 1987.
I also believe that the radiator plastic mounts did not match up to the radiators but you could create a new mount pretty easily.
Thanks for the help Paul.
