2003 cr85 help
Hello everyone, i bought a cr85r last year just to mess around with from a local dirt bike shop. They never said anything about new top ends or anything. and i was just wondering how long a top end lasts in a 2003 cr85r. And i noticed it hitting power band a little slower and bogging a little bit more.
Top ends on the CR85s last a different amount of time on different bikes with different riders. My son has a 2003 CR85RB and we replaced it when he first got it just over a year ago (so we knew what we were starting with) and have seen the performance dip a little. Once we get his 05 going, we will refresh the 03 and give it to his friend. The best way to check the top end is with a compression tester, or if you have the funds, go ahead and change it out. The bogging could be your carb might need cleaned or jets are starting to clog up. My recommendation on the smaller bikes is to go ahead and replace the piston and check the cylinder, make sure your ring gap is within recommended tolerence, put a new plug, clean your carb and then make sure your jetting is on. Enjoy the bike and this site, lots of help to be found here.
Jim
Sorry it took so long. My friend did a complete carb and engine cleaning and degreased everything. Compression on the top end came out to be 107. Which is pretty high for 85's. I heard normal is 90-100.
I've never had a cr 85. I've never had a 2t run less than 125psi. If one did I replaced it. Are you kicking it with the throttle wide open?
My EG built 2001 CR80 (bored to a 105) is harder to kick then my 94 CR125 that EG bored to a 144. The 144 has Just over 150psi on the compression tester. I would assume that the 80 has closer to 180. You are WAY low on compression there.
Well thanks for the help everyone, im kind of new to the dirtbiking community, and im planning on buying a cr125 or 250. May i ask what the best type of top end would be to put it in real quick, then sell the bike. And ive seen people posting about kicking it with the throttle wide. Is it needed?
OEM would be a good way to go if you just want to freshen the top end and sell it. Make sure you save your reciepts though so you can prove a new top end is in it. I like to use the wiseco top end rebuild kits on my bikes. You can get them for a really good price and free shipping from the link below.
EDIT: correction, looks like the 85 top end kit doesn't qualify for free shipping because it is under $99. But still a great price for an entire top end rebuild kit for under $90 after shipping charges depending on what type of shipping you choose.
http://www.oemcycle.com/Item/product/5536/
Thanks, do youu have any idea on a good selling price for a cr85r. Its 2003, new decals, new top end, new back tire. Clean. I was thinking of putting it on for 1.1 grand, and getting talked down to 1 grand.
You may want to look in the local classifieds at similar bikes and price it accordingly. That would be a good deal here in utah but I don't know what your market is.
Here in AZ for an 03 as you describe, about $800 - $900 would sell. There are quite a few I have seen on CL for a while asking over a grand. But each area is different, good luck with it.
I sent you a PM
Jim
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
