03 crf459r please read.
If i trimmed the air inlet holes on my side panel to be a little bigger to let in more air flow, would that give me better throttle response? would there be bad thing about this?
I don't think it helps that much if at all. I had an 03' and what helped it was a JD jet kit and a Boyesen Accelerator Pump cover. If you are looking for low end response you might wanna go up a couple of teeth on the rear sprocket or up one on the front sprocket. The pump cover and jet kit got rid of a little bog the bike had at lower speeds. Just my .02
If you want more response put a new 13.5:1 piston in the tired old beast.
