07 YZ 250 Settings
Any one done mods to there YZ
I'm 220 lbs riding trails N CA
My manual says
stock
fork 4.2
shock 4.8
ive checked race techs specs
anyone changed settings ?:smirk:
thats 0.43 and 4.9 in US spring rates.
I recommend to use 4.4N and 52N for your weight.
Other settings is up to you, how do you feel it and what do you want it to do or not to do.:smirk:
thought 4.3 was small
what is the conversion on the shock
and recomendations
I am 100kg's and run a 4.6kg front and 5.6kg rear, sag numbers are good front and back (I have a long rage ank on and a l camel pack)
just got my new springs in but haven't ridden yet. I'm 195 lbs and I got 4.6kg front and 5.3kg (I think) on the rear.
At 220 you should def. upgrade springs at least. I think the stock springs are rated for a 160lb rider. This ain't Japan.
STU2
what do you run your clickers at
what type of terrain
long range tank and camel back ?
Yes its a 250f now but my last race bike was a 2009 Yz 250, and on that bike I ran .48kg fronts and 5.6 rear, it was too stiff for off road riding, I now running a .46 front and 5.6 rear on the 250f and get good sag numbers, so you would most likely need .45 or .46 fronts, and 5.4 or 5.5 rear
Was just giving you a ball park to aim for
I race harescramble and enduro, I vary the clickers depending on whatrace I am doing, for faster stuff I usually go 3 clicks harder on comp on forks (from 15 out to maybe 12) rebound I alwats leave around 10 or 11 out,
My shock is something I am going to be doing this week as it needs some work so my clicker settings their would not help
are you saying softer front
or revalve
my forks feel stiff they dont travel much
the manual says 4.2 is that to soft
im about 15 comp 10 reb on the forks
12c 10 r on shock
i got a 5.6 rear and stock ? fork
I've been running 4,6N and 56N @ 220lbs on the 09 yz250.
