DR 200 turn signals
I recently replaced by back turn signals with LED. The front 2 are original. Now I can't get the turn signal to work at all. How do I fix the problem?
Buy an LED flasher, replace your existing one. The LEDs do not draw enough current to activate the flasher. Some flashers act as though a bulb is burned out, some don't work at all. An LED flasher is the correct way to fix it will cost about $15. You might be able to find one in an auto parts store, if not, eBay is littered with them.
