base valve all busted up
as i was changing the iner-cylinder oil on my 2008 yz250f i noticed the plastic piston that has the two o rings were covered in hairline cracks? ***! anyone heard of this problem and what should i do? thanks a bunch. want to go brap!
You probably need to replace it. Those pistons are actually made of a thermosetting polypropelene because of their resistance to chemicals such that are found in suspension fluid. Although this is a good material for the job, they can be quite brittle and do sometimes crack. Can you post a picture?
i put it back in so no pic now. they had micro horizontal cracks running all through them. should i go to yamaha or is that part replaced at the tuning shops when they do the custom set up. thank you!
they probably will brake soon. its frequently asked here, just picked the last 2 posts:
http://www.thumpertalk.com/forum/showthread.php?t=984288
http://www.thumpertalk.com/forum/showthread.php?t=952026
You can get them from KYB dealers, eg Smart Performance, MX-Tech, Enzo Racing, etc
I'm not sure if you could get them from Yamaha. but even if so you don't want to buy them there because most likely they would cost a fortune.
