2011 Spring Trade/Buy
I have a 2011 KX450F with stock black spring which is probably a 5.4 and I need a 5.1. any heavier guys want to trade out or sell one they swapped out already? I can only get 90 mm sag with my stock spring, also I am not 100% positive they have the same dimensions, maybe someone here know. I posted on here because there is alot more stock lighter springs than on the 450 side, I am right about 155lbs with gear, so if your around 180 or so this would be perfect. Thanks
Edited by sherco67
Any showa spring will work as far as I know, I ran a stock spring from a honda 250f on my 07 kawi because a friend had it sitting there and was to heavy for it, and the previous owner of my bike was around 100 pounds soaking wet.
Yes, showa springs are showa springs. But The 450 isn't showa, it is Kayaba.
forgot about that, then you need a shock spring from a kayaba set up.
