sealant between exp.ch. and silencer
Im getting some leakage between the silencer and where the expansion chamber meet. Yeah i know theres a rubber boot but it still spurts out.
Not a ton but enough to be annoying when it comes to cleaning.
Is there some sort of sealant that can be used with the rubber boot to seal it up?
Thanks
Thanks
Put two zip ties on the rubber boot.
I goop a good ring of high temp silicone around both ends of the boot as it all gets slipped together. This seals it and lasts quite a while. That ziptie idea sounds pretty slick....why didn't I think of that? I'll try that next time on this spoogy cr125 around here.
That or safety wire. they both work for me.
I would jet it right so it does not spooge out and make a mess.
But if that does not work all of the above are good ideas.
