KTM 300 EXC, baseline jetting
TT,
I have a '00 300 EXC that i'm working on for a buddy. Previous owner "knew how to work on bikes", well in the process has screwed the carb all up. From jets to needle positions and fuel screw. Basically I'm looking for a good baseline jetting, needle clip position, fuel screw turns to start with.
We ride in Maryland about 10 mins from Budds Creek, nice and humid here with about 80-90 degree temps. He's a decent C class rider. Any suggestions???? Ill be tearing into the carb tomorrow morning, Ill post the current specs and jets then
Thanks in advance!:smirk:
I have an '02 KTM300 EXC. I have the following specs: pilot jet is a 42 in summer, 45 in winter, CEK needle with clip in 2nd pos. from top/3rd pos. in winter, 172 main jet in summer and a 175 in winter, airscrew about 1 1/2 turns out. Hope that helps
Little Jeff
thanks for the input. my specs are as follows:
Pilot: 45
Main:175
Needle: NOZH 3rd clip from bottom
Fuel Screw: about 2 turns
Forgot to add it has a FMF gnarly pipe, titanium 2 silencer, power now carb insert, v force 3 reeds.
Cleaned carb out. started 3rd kick. set idle screw. starts first kick now...runs like crap though, super rich. Tomorrow i'm going to a 42, 172, new plug and better fuel/oil mix. idles and putts around great, any throttle at all and its choking up. need to double check fuel screw as well.
Pilot: 45
Main:175
just remember that the main jet has no play till WOT, so if it is blubbery down low, work with those circuits and use a plug chop or wet oil line method for the main. the NOZH series is known to be blubbery down low. There are better needles.
new plug brand new 93 octane fuel mixed 40:1 and its still terrible. idle and minimum throttle are good, pulls front wheel no problem. but once u go past 1/4 throttle its bad. could the powervalve be an issue??? Is there a seperate fuel screw on this carb? the only one a see is the idle/air screw (black knob with spring behind it). still waiting on the 172mj and 42 pj, it should still run better than it is now even with the 45 pj.
There should be two screws.
The black one with the spring is the idle screw, to the lower right of this screw you should see a brass screw. It is just above where the float bowl attaches to the carb, this is the air screw. It may be covered with dirt.
check the ThumperTalk parts store, I think they have exploded views.
Good luck!
That is the issue the nozh needle causes. Ditch the the needle and then tune it. There are much better needles.
