Oil from behind front sprocket '86 KX250
I just bought this 96 KDX200 with an 86 KX250 motor in it for $300. I've read a thread about doing this on a 2006 KX250F, is it the same procedure for my 86? Take off the front sprocket, remove the spacer, and replace the two o-rings?
This is the gasket set I bought because the top end was in pieces.
http://cgi.ebay.com/ebaymotors/Kawasaki-KX-250-KX250-1985-1986-Top-End-Gasket-Set-Kit-_W0QQcmdZViewItemQQhashZitem1c1bf7dc96QQitemZ120728312982QQptZMotorcyclesQ5fPartsQ5fAccessories
Are the two rubber o-rings in this kit the ones I need to put behind my front sprocket?
Thanks in advance for any help
the 2 o-rings are only half of the seal and the more common part to go out, the other part is the actual seal around the spacer. it could be this seal and the spacer (spacer gets a wear groove) or the 2 o-rings. try the o-rings first. i would replace the spacer at the same time, its cheap.
and no, thats a top end gasket kit, these o-rings are part of the bottom end; the o-rings in the top end kit go on the pipe. you need to order them from kawi, or match them up from an o-ring kit, or buy a "complete" or "bottom end" gasket kit which includes the seal and o-rings
Yea. I susbrcibed here to learn anything.
I have a 1991 KX250 I just bought for $700.
It weeps, drips oil from behind the sproket too.
I ordered a "seal" for that off the parts drawing. Hope it works.
I ordered a top end gasket set and piston set too.
Looking forward to wrenchine on my "new" MX bike.
Fry, lets see a pic of your old one.
When I was a kid in HS, I had a 1978 or so. "Anniverary special" with gold rims. Twin shocks in the rear. I think drum brakes too. I should try to figure out which bike that was. It was air cooled. 250
Coo
go look at my how to in the stickys, if its like mine (kdx200) it all should apply
I thought I put two pictures in my garage of it Coo, but here are two pictures of it in my buddy's garage just before we started getting into it. You can't really see the motor all that well though. I'm going over there tomorrow to do more work on it, I'll post some more pics for you then.
I couldn't find the how to in your sticky Sean, but I found this exploded image on the net. 92027 is the spacer I assume and the o-ring I need to replace is 92055 right? Does the spacer just slide out? I think I'm missing the spacer and that's probably why oil comes out. :smirk: Thanks for your help Sean.
If I can stay motivated with working on it I want to strip it down to the frame this winter, paint the frame black, anodize the rims black, and change out the purple plastics with white or green. I have a new black seat cover on order right now to cover the purple. Then add whatever decals I can come up with.
nice ride, i just fixed the countershaft seal on my 89 kdx200, it was very easy. the PO didnt have any O rings in there and made up for spacing by putting a circlip behind the sprocket. it leaked like hell.
all of the parts came to just under $50. its very straight forward, my only advice is to stop pushing the seal in when i gets flush bc it will keep going in past flush. check out this thread:
http://www.thumpertalk.com/forum/showthread.php?t=646957
that would be my how to :smirk:
There it is... lol Thanks buddasahk
Nice how to Sean... The first seal came out with no problem, now its just getting that collar out. It should just slide out right?
Fry
I'm thinking this is all I need to replace, this one o-ring and seal. Just wanted to make sure this was it.
make sure there shouldnt be 2 orings
Nope... there is only the one o-ring. I'm still waiting on the seal to get here. We finally got the bike to kick but no spark. Found that the wiring is all screwed up.
Mine was dripping oil all the time.
Thought it was the seal behind the sproket as that is the #1 cause.
Bought the oil seal and finally got tired of all the oil spots in my shop so attacked it last night. Was bit worried that the old seal didn't just "pop out" with a screw driver prying it. But worked it for a while and got it out. Wire wheeled the spacer as it did have some pitted surface. Put it all back together and....still leaks. I take the brake lever off and tighten all the screws on the oil cover casting. I can see where it's weeping. Sure enough, there is a small hair line crack there.
So, I'll take it off tonight and bring it to the local welder for a quick tig-job.
But good to know it has a new oil seal in there and nothing terrible wrong with it and can keep topping it off. A new oil cover casting (the second one in, the larger one with the fill plug an all) is $175 bucks. A new brake pedal is $95. The pedal has a lot of play in it as the hole for the pin is all elongated so I'll get that tigged up too. Might cost a whole $20
Just updating this old thread
Coo
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
