[[Template core/global/plugins/realFaviconGenerator does not exist. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] Jump to content
Engine Sparking Need Help
I have an Xr75 and it is missing. I noticed that a spark was coming off the pipe to the rear brake. I thought it was a bad ground so I hooked up a Ground from the motor to the shock bolt. It killed the motor just like a kill switch. I have changed the stator, points, condensor, Coil and rewired it. Also disconnected the kill switch. Here is a video of it. Any ideas?
Take some pictures of the upper coil and the wires going up to it and post them. Maybe something will jump out at us.
