cant get fcr-mx BACK in right
I took it out to rejet it and now its like the intake boot from the air filter side is to short...it wont pull up on the carb for some reason...are there any tips to reinstalling that im just missing?
unbolt the airbox, hook everything up and then bolt the airbox back on
put the carb in the air boot,tighten the clamp then pull it foward into the intake manifold.
Use a bungee cord to help keep the subframe pulled forward while you work the carb into the manifold. Pull it farther forward than its bolted position.
