is this bad
hey got a little problem i think?when im in gear with the clutch pulled in ,in low revs the bike vibrates :bonk:is that bad?
Edited by cr125r96
at the same engine rpm in neutral does it vibrate as much? and i do think if it is below a certain rpm it will vibrate a bit more. like when you let the clutc out a little with no gas.
in neutral its fine,i think it drags a bit ,i haven't rode the bike for a month and hopped and noticed it when i was goofing around ,:smirk:
*Facepalm*
If you weren't riding a 125 that's all I'd say...
Yes it's totally normal, it's not a road bike, it's a race bike, it has all those sounds and sensations of a race bike, one of those sensations is a ton of vibration. (No pun intended to the older guys :prof:)
You should try riding a CR500 :smirk::banana::smirk:
